8-Gravel
July 10, 2023
How to monitor bound property quality in TWX and trigger other services
  • July 10, 2023
  • 2856 views
Dears,
I have amount of bound tags(greater than 1000) needed to monitor. When any quality turns to bad or other status except good, subscription should be triggered to send info. How can I config event or subscription to get this with minimal impact on system stability.
Thanks.
Best answer by VladimirRosu_116627
Hi @LeoChen ,
Your subscription code requires a fix, because you're verifying the value at the end, and you should look at the quality.
The first part will also always evaluate to true and even if you compare the oldValue to newValue, it's still simpler to just look at the quality:
if (eventData.newValue.quality!="GOOD")
Hi @LeoChen,
Kindly refer the attached link. I hope it may be helpful in your query.
Monitor Quality of Tags:https://community.ptc.com/t5/ThingWorx-Developers/How-to-monitor-the-quality-of-the-bound-tag/td-p/710794
Thanks & Regards,
Arun C
LeoChen8-GravelAuthor
8-Gravel
July 10, 2023
Thank you. But I need to know how to minimal impact on system. Because the count of property is to much,
Now I creat subscription with the event of AntDataChange,which is not very well.
8-Gravel
July 21, 2023
subscription is very simple.
