Issue trying to import Frame Layout extension
  • March 10, 2020
  • 2 replies
  • 3256 views
having trouble trying to import the Frame Layout extension to one of our Thingworx servers. We have a number of test servers where I was able to import the extension without any issue. However, when I try to import it to our 'live' server it does not import and shows the following error in the logs.
The extension 'FrameLayout_ExtensionPackage' version [1.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
It passes the validation test prior to trying to import, but then fails on the actual import. All the servers are running the same version of Thingworx ( 8.2.8-b856).
I've seen previous posts refer to the platform settings json file, but all of ours are the same (None of them include the "ExtensionPackageImportPolicy".
Would anyone have any thoughts on what might be happening here, or ways around this?
TIA,
K
Does anyone have any idea
khayes11-VisitorAuthor
The full list from the logs is:
Starting entity import of /ThingworxStorage/extensions/temp/85-FrameLayout_Extension_v1_0_57131ee2-49d5-4a92-8c01-0a38e4c730ef/85-FrameLayout_Extension_v1_0/metadata.xml
Deprecated extension structure: The element, FrameLayoutDefaultStyle, was found in metadata.xml and is a deprecated pattern for defining StyleDefinitions in an extension.
Please refer to Project and Extension File Structure in the ThingWorx Extension Development Guide for more information.
Successfully added for import /ThingworxStorage/extensions/temp/85-FrameLayout_Extension_v1_0_57131ee2-49d5-4a92-8c01-0a38e4c730ef/85-FrameLayout_Extension_v1_0/metadata.xml
Export file missing version information. No migration will be performed.
Share the extension.zip file.
thanks for the reply, I have attached the version I am using.
K
Community Manager
March 20, 2020
Hi @khayes1.
If you have resolved your issue, please feel free to post it here for the benefit of others with the same problem.
--Sharon
Was unable to resolve the issue. In the end we removed use of the widget and used a different widget (Responsive Tabs) to achieve the same effect.
K
