Kepware IOT Gateway JAVA JRE
For the IoT Gateway to run, KEPServerEX requires a working 32-bit Java JRE or full JDK installation version 7 or higher. At this time, a 64-bit JRE or JDK is not supported. I Just wanted to know if we can use AdoptOpenJRE instead of 32-bit java JRE?
