Setproperty from mashup checkbox
  • August 8, 2016
  • 6490 views
I am trying to set the property of a thing using a checkbox on a mashup.
1. I have put this widget on the mashup, making sure I select the "Dynamic" checkbox. I have also configured the data bindings so that the checkbox "state" is linked to SetProperties."machineON" <bool> on my thing.
2. I have tried doing the above and also ​using the event "Changed" on the checkbox to trigger the "SetProperties" service.
Neither of these seem to work, so when I change the sate of the checkbox and go to its property page, the thing properties do not seem to change.
Best answer by Aanjan
Sorry, now I see the DynamicThings name there. Can you try adding the same MyHouse Thing again with the SetProperties and the widget bindings exactly the same way you have it now but without selecting dynamic when you're adding the SetProperties service?
Kaloyan, you would definitely need to bind the 'Changed' event to the 'SetProperties' service to trigger it. Are you setting a Boolean value for the property as well?
kpashov1-VisitorAuthor
Hello Aanjan,
I have now bound the "Changed" event to the DynamicThings_Thing.SetProperties and the State to the DynamicThings_Thing.SetProperties.MachineON
Thank you for your quick responses,
The .MachineOn is a child of SetProperties. In my particular example, it is called "AirConditionerOn", I was just trying to shorten the names to make them more understandable.
A picture is worth more than a thousand words (this is a slightly amended version of the Getting Started tutorial):
State is set to "False" by default:
The Changed event fires SetProperties and the State is bound to AirConditionerOn (a custom Boolean property on the Thing)
A screenshot of the entire DynamicThings_MyHouse.SetProperties and its children:
