Thingworx Analytics Installation error ERLANG_HOME
  • May 29, 2020
  • 7312 views
My issue is similar to this thread, however I have followed the documentation I believe: https://community.ptc.com/t5/ThingWorx-Developers/Issues-installing-Analytics-Setup-ERLANG-HOME/m-p/655100
I have Thingworx Foundation installed, now I need to install Analytics.
Analytics installation fails. Specifically, "ERLANG_HOME system environment variable is not set correctly. Set ERLANG_HOME to point to where Erlang software is located, for example, C:\Program Files\erl10.0"
I do have installed Erlang and set the environment variable for the system. The installation of Analytics still fails.
Possibly relevant: I have not yet installed Analytics Server, as I don't think that is required.
To troubleshoot this issue I have done the following:
I have set the environment variable to
C:\Program Files\erl10.0\
C:\Program Files\erl10.0\bin\
I have uninstalled and reinstalled Erlang.
I have tried version 21.3 (latest supported version)
I have tried an earlier supported version 20.3 (currently installed).
I have done a few restarts.
Thanks for any assistance you can provide.
Best answer by Matt-H
Thanks @slangley I logged in today to try again and got in using localhost:8080/Thingworx/Composer/index.html
Though I haven't gotten Platform Analytics installed, I'll close this thread off here because we've resolved the problem of getting Thingworx installed (after uninstalling) has been resolved. When I want to try install Platform Analytics again, I will try and if I have any further issues I will create a new thread. This one has been a beast. Thanks to you and also @nsampat  for your help. Hopefully this thread is helpful to others.
Hello @Matt-H ,
Thank you for posting to the PTC Community.
I understand you are having difficulty with deploying ThingWorx Analytics, around the Erlang pre-requisite.
Can you provide more specifics, as Erlang is not required for the Base Application, ThingWorx Analytics Server. Erlang is required for ThingWorx Platform Analytics, which is a separate application.
Are you able to provide the versions of ThingWorx Platform Server, ThingWorx Analytics Server you wish to deploy?
Also, please note, these variables must be set as a System Variable, not a User Variable.
Neel
Matt-H1-VisitorAuthor
Hi Neel,
Thanks for your assistance.
Having restarted my Virtual machine again (this time after a long weekend), I am able to get passed the ERLANG_HOME environment variable error.
The resolution seemed to be:
1. I uninstalled erlang
2. reinstalled the otp_win64_20.3 version of erlang
3. set the system variable once again.
Now I encounter a new error, shown below.
Do I need to install ThingWorx Analytics Server for Windows i.e. ThingWorx-Analytics-Server-Windows-8-5.zip?
I created an appkey in ThingWorx Foundation.
ThingWorx Foundation is running.
Is it possible that I have misread the guides and need to install the ThingWorx Analytics Server and create an appKey there. Is this my mistake?
(I would simply install the server to check this possibility myself, but I encounter the following errors):
Server installation error:
My version of java:
Location of Java:
Environment variables:
Please note that having set the JAVA_HOME system variable (which wasn't set before -- although the same location was specified in System's PATH variable), I now get another error:
I've tired 127.0.0.1 and localhost.
Morning (for me) Neel,
Since yesterday, I installed Kepware server for the heck of it. I got that installed and connected without issues. The connection used was 127.0.0.1 and port 8443 and the appkey I set up with Admin user (against best practice).
I have read the documentation you provided. It seems that I want to install the Thingworx Analytics Server (and enable the analytics extension during installation).
I have tried this morning with various combinations of 127.0.0.1 and local host, and port 8080, 8443, and 80. 8080 gets me the most promising error message:
As the documentation says[1], I need to have Thingworx server installed (as a prerequisite). I still am assuming that this is Thingworx Foundation (which runs a tomcat server).
Is it possible that this new error message is due to failed previous attempts (as per the first paragraph of this comment https://community.ptc.com/t5/ThingWorx-Developers/Thingworx-Trial-Installation-fails/m-p/578557/highlight/true#M31917)
[1] https://support.ptc.com/help/thingworx_hc/thingworx_analytics_8/index.html#page/analytics/analytics_install/thingworx_server_req_2.html#wwID0EU4BS
