how to create two variable table to show values
SS_2318
9-Granite
I need to create table in below format show two products compatibility. So i am not getting which widgets will help to create table with below requirements
Bikash_Panda
(To:SS_2318)
You can use the Grid widget, if you are lookign for dynamic rows and column size. look for configuring the grid using JSON configuration.
Check this: LINK
Bikash_Panda
(To:SS_2318)
Check this: LINK
Hello @SS_2318
It looks like you have a response from a community member. If it helped you solve your issue please mark the reply as the Accepted Solution.
Community Moderation Team.
