9-Granite
Jun 20, 2024 3:54 AM UTC
how to create two variable table to show values
I need to create table in below format show two products compatibility. So i am not getting which widgets will help to create table with below requirements
Jun 20, 2024 7:14 AM UTC
You can use the Grid widget, if you are lookign for dynamic rows and column size. look for configuring the grid using JSON configuration.
Check this: LINK
Check this: LINK
Emeritus
Jun 27, 2024 6:32 AM UTC
Hello @SS_2318,
It looks like you have a response from a community member. If it helped you solve your issue please mark the reply as the Accepted Solution.
Community Moderation Team.
