Hi Team,
I'm trying to put a tooltip to navigate button but failed.
the property is the below.
is there any needed configuration in addition to the text setting ?
From "Help Center" - "Adding Tooltips to Widgets": https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Mashup_Builder/Widgets/CreatingTooltipsforWidgets.html
Some helpful articles:
Hi @Yoshihiko.N.
Which version of ThingWorx are you running? The 9.x releases now use a Navigation function.
Regards.
--Sharon
