Jamal Ashraf
Aug 22, 2025 11:35 AM UTC
Best Practices for Deploying ThingWorx Projects (DEV → TEST → PROD)
Hi Community,
Currently, we deploy by simply exporting projects from DEV and importing them into TEST/PROD. This works, but it also allows quick changes directly on PROD, which isn’t ideal for tracking and versioning.
I’ve seen that PTC recommends packaging as extensions – which gives versioning, rollback, and cleaner deployments – but it also means every change requires a new package and PROD configs can get overwritten.
👉 What’s the best recommended way in practice?
  • Stick with simple export/import?
  • Or always use extensions with versioning?
  • How do you handle quick fixes vs. safe, reproducible deployments?
Thanks for your advice!
18-Opal
Aug 25, 2025 8:00 AM UTC
Here's what I've been doing on about 15 projects so far:
  1. Developers have individual ThingWorx sandboxes / servers using one of the following:
    1. K8s
    2. Local Docker
    3. Installed locally
  2. All code integration happens via Git pull requests. A PR serves as a quality gate, allowing you to do code reviews, run automated checks, test the change on a live instance before merging, etc.
  3. All deployments are automated, you never use Import/Export feature manually, including dev. servers
    1. For dev. sandboxes: Import as Source Control,
      1. In practice this is done by running some sort of deploy.sh script on a developer's machine
    2. For all other environments, including test, pre-prod and prod: Import as Extension.
      1. This is done by a CD pipeline in your Git platform, e.g. via GitHub Actions or Jenkins.
  4. Every time you need to deploy any change (even a small bugfix), you push it to Git, open a PR, once the PR is merged the new extension is built and deployed -- all automatically. In real projects this takes ~5 minutes.
Let me know if you have some specific questions about this setup.
/ Constantine
Aug 22, 2025 11:56 AM UTC
Hi @MA8731174,  look at the reference article below.
https://www.ptc.com/en/support/article/CS403579
18-Opal
    1. K8s
    2. Local Docker
/ Constantine
Jamal Ashraf
Aug 25, 2025 8:27 AM UTC
That’s an excellent setup, and exactly how such processes should ideally be organized.
In my current role, however, we’re not following these standards since I don’t have rights on the production environment. My access extends only to the development server, and we are not the product owner. Still, I was very interested to understand what an ideal setup looks like, so thank you for providing such a clear and detailed explanation.
For now, in my project we will handle deployments as extensions on test and production which is at least better then manually import/export. There’s no PR-based build or CI/CD pipeline in place, and our access is limited to the development environment where we build solutions for other departments within the company. I have recently started using Github extension (Vladimir Rosu) to work professionally.
If in the future I get an opportunity to work more directly with production deployments and come across challenges, I may reach out here again. Thanks for sharing this your approach.
18-Opal
Aug 25, 2025 8:30 AM UTC
You're welcome! I found that exporting as XML locally and using a proper Git client like SourceTree gives me more control over what goes into the repo, and allows for a cleaner PR / less work for the reviewer.
You can make your process better by writing a pair of shell scripts like export.sh / deploy.sh, to ensure that at least the build, deployment and configuration are fully automated. You don't need PR or CD for that, this is something you can do today.
Sharing a dev server with other developers prevents you from doing a proper feature-based Git workflow with code reviews, but it doesn't prevent you from doing basic source control as such. It's important to use Git as a source of truth for the application's code, not the dev server. Then you can deploy safely at any moment, without CD.
