not able to find "queue" directory after installing dataconnect rpm package
  • November 13, 2017
  • 2 replies
  • 6886 views
I am trying to install thingworx dataconnect 8.0, on centos7 machine.
As mentioned in a DataConnect Installation guide, I need to install Apache spark 1.4.0 with Hadoop 2.4,
but I wasn't able to find the given version of apache spark.
So I used "Apache spark 1.6.0" with "hadoop 2.6" version instead. And installed all the other required softwares.
And upon these third party software setup I installed Dataconnect 8.0. But after installation of dataconnect rpm package,
I am not able to find the "queue" package in /opt/dataconnect directory.
And I also wants to mention that I have installed Thingworx analytics server 8.0 in the same centos machine.
Regards
Rahul T
Hi Rahul,
You could find spark 1.4.0 under the below link:
https://archive.apache.org/dist/spark/spark-1.4.0/
spark-1.4.0-bin-hadoop2.4.tgz download this file from the page then retry the installation using Spark 1.4.0
Hopefully, this will solve the issue you are facing.
Best Regards,
Amine
rt11-VisitorAuthor
I tried the installation using spark 1.4.0 but still I am facing the same issue,
is there any specific reason for this problem?
Regards
Rahul T
Hi Rahul
/opt/dataconnect/queue is not a package. It is the directory where jobs are queued.
From what I could find, if it does not exist it should be created upon first job execution.
Do you face a specific issue while running a job ?
if not, why did you look at that specific location (I am just curious)?
Kind regards
Christophe
Hi Rahul
I notice that you have opened a ticket to Technical Support for the same topic, which is a good idea.
However to avoid duplicated effort and risk of conflicting information, I would advise to keep the activity on this installation within the Technical Support ticket.
We wil ltherefore consider this Community thread closed.
Thank you
Kind regards
Christophe
