Aug 20, 2025 9:07 AM UTC
Unable to push CSDK properties to ThingWorx 10.0.0
I just installed ThingWorx 10.0.0 and created a service that will create
  • User
  • ApplicationKey for this User
  • Organization with a Top Organizational Unit with the User as a Member
After this, the service create a new RemoteThing and sets visibility to the Organization and adds Runtime Permissions (property read/write, service invoke, event invoke/subscribe) and Design Time Permissions (Read).
With the ApplicationKey and thing name I can now connect a CSDK application.
The application has three properties and on changing the status of the "isConnected" property, the Platform will run a service that will create these remote properties on the RemoteThing.
However, when running the CSDK I can see that the properties are connected but they fail to synchronise with the following error in the CSDK:
[ERROR] 2025-08-20 10:58:30,206: twSubscribedPropsMgr_PushPropertyInfoList: Error pushing properties for ON1111-2. Error: 1111.
[ERROR] 2025-08-20 10:58:30,206: twSubscribedPropsMgr_PushProperties: error pushing or persisting property list, code: 1111
This continues throughout any restart of the CSDK (where properties are no longer touched on the RemoteThing). Only when restarting ThingWorx, the properties will synchronise.
Why would this be blocked, but starts working after a ThingWorx restart?
There seems to be some kind of permission issue, because everything works just fine with an Administrator-ApplicationKey.
Thanks for your help,
Michael
18-Opal
Aug 20, 2025 12:05 PM UTC
If you change the owner, then you should be able to remove all other permissions. You might want to check services like SetPropertyValues instead.
Beware — Allowing a remote device own some entities has pretty deep security implications. If I remember correctly, it also grants design time ones, meaning you can impersonate System.
/ Constantine
mneumann16-PearlAuthor
Aug 20, 2025 9:36 AM UTC
- deleted due to a temporary hiccup that made it work.
The issue still continues.
18-Opal
/ Constantine
Aug 21, 2025 9:16 AM UTC
Thanks Constantine!
I somehow managed to make the original issue work.
You have a good point about ownership here.
For now I created a generic user (without password nor any other permissions) that owns all remote devices, and I kept the assigned permissions for the Things themselves. Before that, we had the owner set to whoever created the device, but that put unnecessary ownership questions to the original creators.
