State explode problem with snapshot views
I am trying to define a spare parts catalog but I encounter many difficulties ...
I notice bad behavior in handling snapshots and exploded view created by the "Make snapshot available in drawings" command.
I'll explain:
- I create my snapshot and make it available in the drawings, the program creates a corresponding exploded state.
- I modify my exploded state by spacing components and adding explode lines.
So far so good.
The problem arises if I then need to modify the snapshot, if I update it, the program resets the exploded state !!! Frustrating ...
Is there any procedure to avoid having to redo all the work from scratch?
Thank you
P.S. i use Cro 2.0 M250 and Creo 8.0
