PTC Community Monthly Stand-Out March 2023
achirila
Emeritus
See the Top Community Engagers and the Top Noteworthy posts for the month of March.
Top March 2023 Community Engagers:
@WernerE @HelesicPetr @MartinHanak @tbraxton @avillanueva @Constantine @jensc @VladimirN @StephenW @ttokoro @LucMeekes @d_graham @kdirth @Eike_Hauptmann @Patriot_1776 @BenLoosli @abrinks @SweetPeasHub @terryhendicott @Sathishkumar_C
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for March 2023!  See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: @JA_1434743 asked about Working with more sessions in Creo8Great contributions by @MartinHanak@StephenW@RandyJones.
https://community.ptc.com/t5/3D-Part-Assembly-Design/Working-with-more-sessions-in-Creo8/m-p/865652#M128537
2. Creo:  Adam_048 received an accepted solution from LukMazur for topic "is there a way to show driving dimensions which "origin" extension lines get clipped by x-sections?"Thank you!
https://community.ptc.com/t5/3D-Part-Assembly-Design/is-there-a-way-to-show-driving-dimensions-which-quot-origin-quot/m-p/865208#M128521
3. Creo: Thank you SweetPeasHub for providing an accepted solution for JeffreySabala on this topic - Creo Simulate using saved autogem meshes in top assembly
https://community.ptc.com/t5/Analysis/Creo-Simulate-using-saved-autogem-meshes-in-top-assembly/m-p/860199#M11181
4. Creo: KG_9368596 needed help with this topic - Selecting Creo License on Start -Up and offered him an accepted solution.
https://community.ptc.com/t5/System-Administration/Selecting-Creo-License-on-Start-Up/m-p/865855#M29396
5. Creo: A question about New PC for large assemblies was posted by Chris3 and an Accepted Solution was provided by rreifsnyder. Thank you TrainStopper also for your contribution!
https://community.ptc.com/t5/System-Administration/New-PC-for-large-assemblies/m-p/865065#M29373
6. ThingWorx: @bchaudharygave an Accepted Solution to jgp for the topic Limit of number of properties in the Composer viewer
https://community.ptc.com/t5/ThingWorx-Developers/Limit-of-number-of-properties-in-the-Composer-viewer/m-p/865060#M61731
7. ThingWorx: The topic Flexible containers posted by jensc received an accepted solution provided by
https://community.ptc.com/t5/ThingWorx-Developers/Flexible-containers/m-p/861132#M61523
8. ThingWorx: Velkumar provided a speedy response and Accepted Solution to the inquiry by Hariharasuthan about the topic "i have services code but how to implement schedulers"
https://community.ptc.com/t5/ThingWorx-Developers/i-have-services-code-but-how-to-implement-schedulers/m-p/864191#M61693
9. ThingWorx: ZbigniewK asked about User permissions for timers and nmutter provided a quick Accepted Solution.
https://community.ptc.com/t5/ThingWorx-Developers/User-permissions-for-timers/m-p/864544#M61705
10. ThingWorx: MR_10404102 posted the topic Finding data in json from an infotable and received an Accepted Solution from Sathishkumar_C.
https://community.ptc.com/t5/ThingWorx-Developers/Finding-data-in-json-from-an-infotable/m-p/859350#M61411
11. Vuforia: emmanuel001 shared a post about don´t show symbol in my animation. Thank you ClayHelberg for providing an Accepted Solution!
https://community.ptc.com/t5/Vuforia-Studio/don-t-show-symbol-in-my-animation/m-p/862939#M11596
12. Vuforia: MattBob wanted to Invoke reset tracking Vuforia View function
Thanks  for contributing with the Accepted Solution!
https://community.ptc.com/t5/Vuforia-Studio/Invoke-reset-tracking-Vuforia-View-function/m-p/851548#M11494
13. Windchill:  rburk posted the topic Windchill Task error and received an Accepted Solution by HelesicPetr.
Thank you d_graham and Dobi for your contribution!
https://community.ptc.com/t5/Windchill/Windchill-Task-error/m-p/864076#M70825
14. Windchill: AThomas104 asked How to check in drawings to windchill ? and provided the Accepted Solution. Thank you HelesicPetr and for your contributions as well.
https://community.ptc.com/t5/Windchill/How-to-check-in-drawings-to-windchill/m-p/864094#M70829
15. Windhill: Dobi asked about Add an attribute display field by "state" with an Acccepted Solution from d_graham
https://community.ptc.com/t5/Windchill/Add-an-attribute-display-field-by-quot-state-quot/m-p/864087#M70827
16. Windchill: nbojcetic asked about Problem getting CSRF_NONCE value (HTTP 400)
 and HelesicPetr provided an Accepted Solution!
https://community.ptc.com/t5/Windchill/Problem-getting-CSRF-NONCE-value-HTTP-400/m-p/863664#M70794
17. Windchill: MV_10441462 asked a question about the Best way to download files from Windchill Server to client HelesicPetr  delivered an Accepted Solution. Thank you  for participating!
https://community.ptc.com/t5/Windchill/Best-way-to-download-files-from-Windchill-Server-to-client/m-p/858903#M70479
18. Mathcad: JC_10225320 needed help with Inverse trig function and ttokoro provided the Accepted Solution!
https://community.ptc.com/t5/Mathcad/Inverse-trig-function/m-p/865540#M205859
19. Mathcad: AS_10562569 needed thelp with this topic This Value Must be A Real Number When Plotting Functions and  helped with an Accepted Solution. Thank you ttokoroTH_10592087 and terryhendicott for participating as well!
https://community.ptc.com/t5/Mathcad/This-Value-Must-be-A-Real-Number-When-Plotting-Functions/m-p/864443#M205792
20. Arbortext: Toolbars from IsoDraw 7.3 to 7.4 was khoward's topic, which received an Accepted Solution from bfriesen.Thank you!
https://community.ptc.com/t5/Arbortext/Toolbars-from-IsoDraw-7-3-to-7-4/m-p/861776#M32832
Andra
0 REPLIES 0
