PTC Community Monthly Stand-Out May 2023
  • June 15, 2023
  • 0 replies
  • 646 views
See the Top Community Engagers and the Top Noteworthy posts for the month of May..
Top May 2023 Community Engagers:
@HelesicPetr @Werner_E @avillanueva @MartinHanak @jensc @Velkumar @StephenW @LucMeekes @Dale_Rosema @tbraxton @Chris3 @terryhendicott @BenLoosli @kdirth @Marco_Tosin @nmutter @Dobi @skunks @ttokoro @ScottMorris
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for May 2023!  See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: phammerstrom asked about Export Parameter table as .XML file.
Great contributions by @Lars_F@MartinHanak@pausob@Petterssonrm�ller..
@Lars_F
https://community.ptc.com/t5/3D-Part-Assembly-Design/Export-Parameter-table-as-XML-file/m-p/656262#M63870
2. Creo: @RP_10384451 received an accepted solution from @MartinHanak for topic watermark in creo drawing (.drw).
https://community.ptc.com/t5/3D-Part-Assembly-Design/watermark-in-creo-drawing-drw/m-p/878401#M129368
3. Creo: Thank you @StephenW@MartinHanak for providing an accepted solution for @RD_10565855 on this topic Swept function icon. Thank you @tbraxton  for your contributions!
https://community.ptc.com/t5/3D-Part-Assembly-Design/Swept-function-icon/m-p/878073#M129360
4. Creo: @D_Hale needed help with this topic Boolean Object Selection Issue - CREO 7.0.4.0 - and @pausob offered him an accepted solution. Thank you @tbraxton  for your contributions!
https://community.ptc.com/t5/3D-Part-Assembly-Design/Boolean-Object-Selection-Issue-CREO-7-0-4-0/m-p/877845#M129349
5. Creo: A question about Creo flow (7.0.8) orthotropic thermal conductivity doesnt work
was posted by @BB_9671067 and an Accepted Solution was provided by @tmoser.
https://community.ptc.com/t5/Analysis/Creo-flow-7-0-8-orthotropic-thermal-conductivity-doesnt-work/m-p/876931#M11402
6. ThingWorx:  @nmutter  gave an Accepted Solution to @jensc for the topic Set "General Information" on entity programmatically.
https://community.ptc.com/t5/ThingWorx-Developers/Set-quot-General-Information-quot-on-entity-programmatically/m-p/878191#M62577
7. ThingWorx: The topic Thingworx Upgrade from 8.4.9 To 9.2 posted by
@AntonioFar received an accepted solution provided by TravisPickett.
https://community.ptc.com/t5/ThingWorx-Developers/Thingworx-Upgrade-from-8-4-9-To-9-2/m-p/877980#M62562
8. ThingWorx: @VladimirRosu_116627 provided a speedy response and Accepted Solution to the inquiry by @jensc about "Ordering the network entity"
https://community.ptc.com/t5/ThingWorx-Developers/Ordering-the-network-entity/m-p/877524#M62512
9. ThingWorx: AM_10639709 asked how to Use only selected TLS version in ThingWorx
 and bchaudhary provided a quick Accepted Solution.
https://community.ptc.com/t5/ThingWorx-Developers/Use-only-selected-TLS-version-in-ThingWorx/m-p/877913#M62556
10. ThingWorx:  @KB_10564916 posted the topic Is there any Form Widget for creating forms in thingworx?
 and received an Accepted Solution from @jensc.
https://community.ptc.com/t5/ThingWorx-Developers/Is-there-any-Form-Widget-for-creating-forms-in-thingworx/m-p/874476#M62524
11. Vuforia: @bfriesen shared a post about Find text and replace with an ph element. Thank you @RolandRaytchev@ClayHelberg for providing an Accepted Solution!
 https://community.ptc.com/t5/Arbortext/Find-text-and-replace-with-an-ph-element/m-p/878635#M32893
12. Windchill: @AV_10700549  posted the topic Windchill Risk & Reliability (or WQS) connection with Silicon Expert database and received an Accepted Solution by @VladimirN
https://community.ptc.com/t5/Windchill/Windchill-Risk-amp-Reliability-or-WQS-connection-with-Silicon/m-p/878081#M72114
13. Windchill: SC_8321054 asked about the Deleting the existing user and adding another user at same role and @joe_morton provided the Accepted Solution. Thank you @TDT@HelesicPetr for your contributions as well.
https://community.ptc.com/t5/Windchill/How-to-listen-to-event-while-moving-object-from-one-container-to/m-p/876767#M71961
14. Windhill: @CH_10067600 @KS_9713081asked about getting "5 out of bounds for length 5" error while loading file.
 with an Acccepted Solution from @HelesicPetr@avillanueva.
https://community.ptc.com/t5/Windchill/getting-quot-5-out-of-bounds-for-length-5-quot-error-while/m-p/878433#M72141
15. Windchill: @NSS asked about wt.load.LoadFromFile and @Marco_Tosin@HelesicPetr provided an Accepted Solution!
https://community.ptc.com/t5/Windchill/wt-load-LoadFromFile/m-p/878491#M72150
16. WindchillSB_10566278 asked a question about How to iterate Windchill work Package and  @avillanueva delivered an Accepted Solution.
https://community.ptc.com/t5/Windchill/How-to-iterate-Windchill-work-Package/m-p/878430#M72140
17. Mathcad: @xyz123@ZZ_10687107 needed help with This function requires at least 4 argument
and  @Cornel@Werner_E  provided the Accepted Solution!  Thank you, for also participating in the conversation!
https://community.ptc.com/t5/Mathcad/This-function-requires-at-least-4-argument/m-p/878474#M206884
18. Mathcad:  @PD_10423696@GS_8802941 needed with Importing a set of points from Creo to Mathcad
 and  helped with an Accepted Solution. Thank you @Werner_E@VladimirN@FH_10699016@ttokoro
for participating as well!
https://community.ptc.com/t5/Mathcad/Importing-a-set-of-points-from-Creo-to-Mathcad/m-p/877763#M206823
