KenFarley
Sep 24, 2012 6:51 PM UTC
FIL macro for calculation of cycle time
I've found it's very helpful to include a time estimate for my NC programs, which I put in a comment block at the beginning of the file. Historically, I've manually added this, but there is a way to do it with the filter (FIL) file and a macro. I looked at the PTC macros and found some code that was supposed to do this, but it does not work. Basically, the algorithm being implemented does the following:
(1) Store the current line number from the input CL file.
(2) Switch the postprocessor into "simulation mode", which does not output any actual processed code.
(3) Process the input CL file, one statement at a time, until the end of the file is encountered.
(4) Get the cycle time from the appropriate "POSTF" function call.
(5) Rewind the input CL file to the line immediately after the starting line you saved in (1).
(6) Turn off the "simulation mode".
(7) Process the remainder of the input CL file normally.
This is accomplished via the following FIL file code:
$$---- [ FIL commands begin ] ---------
CIMPOS = POSTF ( 7, 1 ) + 1 $$ Set the return CL position
JUNK = POSTF ( 2, 1, 1867, 1 ) $$ Turn on simulation mode
DO / ENDDO, INDEX = 0, 10
JUNK = POSTF ( 14 ) $$ Get next CL file record
CMDTYP = POSTF ( 7, 2 ) $$ Obtain the CLASS from record
IF ( CMDTYP.EQ.14000 ) THEN
TOTTIM = POSTF ( 1, 3, 495 ) $$ Get the cycle time
INSERT/ '( Est Time : ', TOTTIM, ')$'
INDEX = 11 $$ Force loop exit
ELSE
RESULT = POSTF ( 13 ) $$ Process the current CL line
INDEX = 2
ENDIF
ENDDO) CONTIN
JUNK = POSTF ( 15, CIMPOS ) $$ Reset CL to return position
JUNK = POSTF ( 2, 1, 1867, 0 ) $$ Turn off simulation mode
$$---- [ FIL commands end ] ----------
The result I get is always zero, when I use the above code. If I do the "POSTF ( 1, 3, 495 )" stuff at the end of normal file processing, I get a meaningful time, but don't really want to put that at the end of my NC code file. Any ideas as to why the "simulation mode" doesn't seem to correctly calculate cycle time? Is there a way for me to process the contents of the CL file, then prepend the time estimate on the output file?
Anyone have any pointers on getting this to work?
KenFarley
KenFarleyAnswer
Jan 25, 2013 2:45 PM UTC
So, it's been a while, and I haven't really seen any response. I've tried a number of iterations at methods to calculate program run time, but it seems that the only one that works for me is to do so at the very end of processing the CL file. So, here's my macro for doing this:
$$ --[ Macro : WRTTIM ]-------------------------------------------------
$$ Obtains and outputs the total runtime at the present time, as a prop-
$$ erly formatted comment. Utilizes the always-obscure and cryptic POSTF
$$ function to read the correct common variable.
WRTTIM = MACRO/
MNTIME = POSTF ( 1, 3, 0495 ) + 1.0 $$ Get the total runtime
HRTIME = INTF ( MNTIME / 60 )
CALL/ IN2TXT, INTVAL = HRTIME, NUMDIG = 2
HRTEXT = TEXT/ TXTVAL
MNTIME = INTF ( MNTIME ) - ( HRTIME * 60 )
CALL/ IN2TXT, INTVAL = MNTIME, NUMDIG = 2
MNTEXT = TEXT/ TXTVAL
TXTPRE = TEXT/ '( E', (TEXT/LOW,(TEXT/'st ')), 'T'
TXTPRE = TEXT/ TXTPRE, (TEXT/LOW,(TEXT/'ime : '))
TXTHRS = TEXT/ ' H', (TEXT/LOW,(TEXT/'ours '))
TXTMNS = TEXT/ ' M', (TEXT/LOW,(TEXT/'inutes'))
INSERT/ TXTPRE, HRTEXT, TXTHRS, MNTEXT, TXTMNS
INSERT/ ' )$'
TERMAC
My current "solution" is to just write this at the end of my processed file, then hand edit (unfortunately) and move it to the beginning of the file. The reason for moving it is that many of the programs I'm generating are really long, and the drip feeding program we use only shows a small portion of the file in its preview. This way the person running the program can get an idea of the amount of time the program will take and plan accordingly.
KenFarley
KenFarley21-Topaz IIAuthorAnswer
WRTTIM = MACRO/
INSERT/ ' )$'
TERMAC
KenFarley
Jan 25, 2013 2:49 PM UTC
Just noticed I have a call to "IN2TXT", another macro, in that posted code. That particular routine converts a supplied number to a specific number of digits, storing it in "TXTVAL". If you are interested, here it is:
$$ --[ Macro : IN2TXT ]-------------------------------------------------
$$ Converts an integer value to a text string, with the desired
$$ number of characters. If necessary, the number is padded with
$$ leading zeroes to achieve the desired width.
$$ Parameters
$$ INTVAL : the value that is to be processed
$$ NUMDIG : the number of characters the number is to fill
$$ In order to properly use this macro, a "global" variable called TXTVAL
$$ must have been declared in the program. This is due to the fact that
$$ macros allow for input of parameters, but not output.
IN2TXT = MACRO/ INTVAL, NUMDIG
WRKVAL = INTF ( INTVAL )
DIGSOK = 1 + INTF ( LOGF ( WRKVAL ) / LOGF ( 10.0 ) )
NUMZED = NUMDIG - DIGSOK
IF ( NUMZED.GT.0 ) THEN
TXTVAL = TEXT/ REPEAT, NUMZED, '0', CONVI, WRKVAL, DIGSOK
ELSE
TXTVAL = TEXT/ CONVI, WRKVAL, NUMDIG
ENDIF
TERMAC
