Drawing Template Repeat Region
- 19 replies
- 9776 views
- Translate All
With a Drawing Template, I want to create a repeat region on drawing from the model, looking for any parameter that is named for example below :
SPEC_G_1245 and show in table as G-1245
SPEC_111345864XX and show in table as 111345864XX
Each parameter will have value and description that will be output as a column. Should look like picture attached if outputted correctly. I am not very familiar with table relations but this would benefit us a lot as we are trying to move more to parameter based notes for drawings.
