Chris3
Model of a US quarter?
  • September 24, 2010
  • 19 replies
  • 5203 views
Does anyone have a model of a US quarter? I would like something a
little more detailed than just the thickness and diameter. I want it to
show the scale of some things when I make print outs.
Chris
I believe the US Secret Service would not look favorably on someone modeling a quarter, or any coin.
They would consider that a form of counterfittng.
Thank you,
Ben H. Loosli
Couldn't you apply a decal to a cylinder that matches the diameter and thickness of a quarter?
Timothy
Chris3
Chris321-Topaz IAuthor
Actually the Secret Service is fine with it:
18-Opal
September 24, 2010
I think I would model it as a flat washer without the hole and map an image on one side...
Chris3
A lot of people have suggested just applying a decal to the model. I can
do that. Thanks for the help.
Chris
So according to what you posted this would not be a good way to show scale
of a part as I believe the original poster had intended, because the first
stipulation is...
1. The illustration is of a size less than three-fourths or more than one
and one-half, in linear dimension, of each part of the item illustrated
And re-use would be difficult because of the item 3 listed.
3. All negatives, plates, positives, digitized storage medium, graphic
files, magnetic medium, optical storage devices, and any other thing used
in the making of the illustration that contain an image of the
illustration or any part thereof are destroyed and/or deleted or erased
after their final use
Brian S. Lynn
Technical Coordinator, Product Engineering
Uh, not really, It's first requirement is that it be out of scale, so it
would not help you to have it as it is not the correct scale anyway.
The Counterfeit Detection Act of 1992, Public Law 102-550, in Section
411 of Title 31 of the Code of Federal Regulations, permits color
illustrations of U.S. currency, provided:
one and one-half, in linear dimension, of each part of the item
illustrated
2. The illustration is one-sided and
graphic files, magnetic medium, optical storage devices, and any other
thing used in the making of the illustration that contain an image of
the illustration or any part thereof are destroyed and/or deleted or
erased after their final use
Title 18, United States Code, Section 504 permits black and white
reproductions of currency and other obligations, provided such
reproductions meet the size requirement. See the section on this website
entitled Know Your Money
<">http://www.secretservice.gov/know_your_money.shtml> for more
information.
Chris3
The requirement is that the illustration is not to scale. My poster will
not be to scale - if it was, I wouldn't need the quarter in the first
place.
Chris
That print could definitely be used for scale.
The delta between it and an actual item can easily be seen understood. It has real ramifications for being wrong and shows the importance of scale.
I would suggest not using it as an honest error may have new people introducing themselves to you followed by them showing you their badges.
Feel free to contact me with any questions
Why not, just create a disk the size of a quarter and then put text on it US Quarter Equiv.? Simple, straight to the point, and avoids any potential for problems with the government.
Brian S. Lynn
