Feedback and torque control
- December 11, 2018
- 7 replies
- 7760 views
Hello everybody,
I would try to implement a PID control over a simple crank connecting rod.
The system starts from standstill and has to reach a normal velocity of 3 rev/sec. The motor has a normal torque of 8,5 Nm and there is a force of 50 N along the "piston" axis.
I set the analysis as described in the attached PDF; the only difference is that in the example the motor has to fix the bar, so the final position is a fixed value and its velocity is zero. In my case the maotor continues to rotate; the desired velocity is the nominal one of 1080 deg/s and the desired position is (nominal_velocity * T).
I have two problems:
- I don't know the right value for the PID's constants.
I tried to run an optimization analysis to minimize the velocity error (intended like the absolute value of error) but I can't insert it like the goal. - I would limit the torque (in my mind the motor is a brushless) inside its operational field delimited by a max value for torque and velocity.
Any suggestions are welcome!
PS: I used Creo 5 for making the example.
Bye
