KenFarley
Mar 28, 2014 8:36 PM UTC
Model with simple frustrum - volume calculation wrong
I make a lot of models that involve pyramidal frustrums (transition of a rectangular section to another rectangular section, linearly). Rather than use the measured value calculated by Creo, I thought I'd have a go at calculating the volume directly from the dimensions.
When I check my calculations, the volume calculated directly from the dimensions differs from the Creo analysis result.
I minimized the accuracy value, but still get the exact same result.
Here are my simple values
Base rectangle: 5 X 3 -> Base area: 15
Top rectangle: 4 X 2 -> Top area: 8
Height: 1
Frustrum of a pyramid volume is
Volume = ( Area Base + Area Top + SQRT ( Area Base * Area Top ) ) * Height / 3 = 11.3182
Creo, on the other hand, gives a volume of 11.3333.
Anyone have any insights into this?
This is simple shape, and kind of scares me about what might be happening with more complicated geometry.
    dschenkenAnswer
    2-Explorer
    Mar 28, 2014 11:56 PM UTC
    I think Creo is right.
    I'm not sure where the formula came from but ...
    L = l_base - ((l_base-l_top)/delta_z) * Z
    W = w_base - ((w_base-w_top)/delta_z) * Z
    A = L * W =
    l_base*w_base
    - (l_base*((w_base-w_top)/delta_z) + w_base*((l_base-l_top)/delta_z)) * Z
    + ((l_base-l_top)/delta_z)*((w_base-w_top)/delta_z)*Z*Z
    Integrating:
    V =
    l_base*w_base*Z
    - (l_base*((w_base-w_top)/delta_z) + w_base*((l_base-l_top)/delta_z)) * Z*Z/2
    + ((l_base-l_top)/delta_z)*((w_base-w_top)/delta_z)*Z*Z*Z/3
    Plugging it all in I get 11.33...
    dschenken2-ExplorerAnswer
    2-Explorer
    A = L * W =
    l_base*w_base
    Integrating:
    V =
    l_base*w_base*Z
    2-Explorer
    Mar 29, 2014 1:40 AM UTC
    I should be able to simplify the integral to be the same as the original formula, but so far no luck. I looked at the Wikipedia page that showed the derivation of the original formula, but it doesn't yield terms I can yet convert.
    I get 11.3182 from the original formula, but don't see the reason for the discrepancy.
    KenFarley
    KenFarley21-Topaz IIAuthor
    Mar 29, 2014 4:48 AM UTC
    I got the original formula from the CRC math tables. A handy book from olden times which has all sorts of nice answers to unusual geometry questions. It's an odd conundrum. One would, reasonably, expect any sound mathematical method to yield the same results.
    I can see where your integration comes from, and how it gets the number Creo gets. But still, I wonder if I'm missing something crucial about the frustrum...
