Cycle through worksheets with Readfile
  • September 17, 2010
  • 3 replies
  • 19106 views
Hello folks,
I have about 80 Excel files with each containing 24 worksheets full of data. I'd like to cycle through each Excel file's worksheets to read out the data in a loop using Readfile. For obvious reasons doing this via the import wizard is too cumbersome.
Readfile however does not offer to choose a certain worksheet within an Excel file. Has anybody an idea how to overcome this shortcoming?
Thanks in advance
Raiko
Raiko Milanovic wrote:
Hello folks,
Thanks in advance
Raiko
Raiko,
Can you post an example, think I've got something that will work.
Mike
Please see attached worksheet.
Tom Gutman posted the sheet a while back which writes data to multiple worksheets within a Excel file. I am hoping Tom or another collab can modify the script in the textbox so data can be read from mulitple sheets instead of writing.
Mike
Another example.
I have used an Embedded Excel component and specified each of the sheets when defining the data range. One problem is that M14 is only compatible with Excel 2003 - Will this be a problem?
Mike
Fred,
That is a fantastic piece of work, well done.
Raiko,
Have a look at the attached worksheet – It reads data three different worksheets within one Excel file. For your example you could write a function to loop through each of your sheets.
I have also attached an image to prove its working on my machine
Mike
Raiko17-PeridotAuthor
Fred, Mike,
many thanks for your effort.
I still have a problem with the scripted object, as the debugger maintains that it doesn't know/support the the GetObject method.
Any suggestions?
Raiko
Raiko,
Are you using Mathcad 14 & Excel 2003 formats?
Have you got the correct directory when calling in the file?
Once you have changed the directory to suit your computer,right click on the object and click edit script. Hit the tick at the top, this seems to reset the script from the last process.
I have modified the worksheet - It now succesfully calls your data.
Mike
