CAMU Error code -23
  • July 27, 2005
  • 3 replies
  • 881 views
Does anyone remember what ERROR CODE -23 means in CAMU?
Thank you,
Joe
Joe Haines
Engineering Systems
CNH America LLC
500 Diller Ave
MS 631
New Holland, PA 17557
PH 717-355-3699
FX 717-355-4091
    Joe,
    This usually means that the ODB_DAEMON process is not running on the
    DB_DAEMON_HOST machine.
    Check your .caddsrc/.caddsrc-local file for what DB_DAEMON_HOST is set
    to, then run /usr/apl/cadds/scripts/db_daemon on it. You also may need
    to check permissions, as the user that the ODB_DAEMON process is running
    under needs to have write access to the _db file.
    Best regards,
    Andy Bruce
    PTC Global Services
    Manchester UK
    JoeH1-VisitorAuthor
    Turns out to be a corrupt assembly. Got an older copy from backups and it
    comes up fine.
    Joe
    Joe Haines
    Engineering Systems
    CNH America LLC
    500 Diller Ave
    MS 631
    PH 717-355-3699
    FX 717-355-4091
    Excellent follow-up.
