I am using Creo Parametric Release 4.0 and DatecodeM150
Hello
I am using the relation RAW_MATERIAL_WEIGHT=PRO_MP_MASS:2 in my manufacturing .asm to show in 2D drawing of my Manufacturing Setup sheet the Weight. The number :2 refers to the ID of my Raw model. But when I save a copy Drawing / .asm and replace the model of raw material the parameter PRO_MP_MASS:2 doesn't update and in my drawing, the parameter keeps with the weight of the previous one. Do you have any suggestions to solve this problem?
Hello
Hi CrisAfarelli,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Community Moderation Team
