2d linear interpolation
  • March 5, 2018
  • 4313 views
Dear all,
I'm facing again a problem with linear 2D interpolation.
In this case I tried to see if the results of direct and inverse interpolation coincide.
z=f(x,y) and y=f(x,z).
Unfortunately, they don't.
Could you please help me in finding the solution of this problem?
Attached you see the mathcad file.
Thank-you very much for your support.
Enrico
Sorry, but I see no reason why the two diagrams in your sheet should coincide.
Your first table yields a value for cycles  of 35309 if force=16574 and ratio=0.2.
Your second table suggest a cycle value of just 100 for the same values. Obviously different functions.
ebelmonte1-VisitorAuthor
Dear Werner,
Thank-you very much for your reply.
You are right. I've sorted out the file. Now it should be clearer.
I still find some difficulties by interpolating the data.
I really appreciate your support!
Enrico
Dear Werner,
The discrepancies are possible since a low variation of the stress can lead to a big variation of the number of cycles.
The S-N curves are linear if x- and y-axis are logarithmic.
I think that the data are too much apart from each other for linear interpolation.
I tried also the following interpolation
which is working better for low number of cycles but poor for high number of cycles.
Do you have any idea how I can deal with this issue?
Thank-you very much!
