Hi. I know that this is a Mathcad forum. But i have a problem and i don't know how i can resolve.
You have a TRX system: https://www.youtube.com/watch?v=MbybxX5cXBE
and you want to determine the following with a sensor based system:
1. the energy spent during workout
2. the correctness of the exercises
How do you physically determine 1 and 2?
What sensors do you need?
How do you use the sensors?
(The sensors must be placed by the TRX system)
I thought to use 2 IMU sensors and one load cell sensor. But i don't know how i can determine the correctness of the exercises. Any help would be highly appreciated!
To meassure the data of effort, it's a very complex task and situation.
There are so many parameters to be taken into account to make a correct measurement.
The physical work of our body when making sports cannot be compared with the mechanical work.
I can pull a weight og 5kg 20times at a hight of 1m: The calculation of the power which is mechanical done is easy to do, but the bodyworkout is not that easy to calculate (measure).
