Knowledge Base Search Broken?
  • May 4, 2020
  • 5 replies
  • 13707 views
Is it just me, or is the knowledge base search ignoring all of us?
Best answer by dhermosillo
Yep, it's working again.  Thanks!
DomenicLaritz
At least I have the same problem right now!
Community Manager
May 4, 2020
Hi @jimh and @DomenicLaritz. We're looking into this and are not currently aware of any issues on production Search.
To help with our investigation, could you please share some details of :
  • Symptoms you're seeing including any error message(s)
  • The approximate time you see the problem
  • The browser you're using, and
  • Whether the problem still persists after a refresh with Ctrl + F5 ?
Many thanks in advance
jimh12-AmethystAuthor
When I go into the knowledge base search, I just don't get any results.  No errors, just nothing returned.  Just to make sure it wasn't my search, I tries searching for "API" then "PDMLINK" and got no results.
I tired with Edge and IE.
Refresh doesn't help.
Please see attached files.  Seems to work on the old search page, but not from the support landing page.
Same effect on my side.
After entering a search term an hitting the search icon or enter, search text is deleted an no search results are displayed.
Working fine for me with Edge.
It appears to be broken again today.  The eSupport home, https://support.ptc.com/, returns 404 error in all browsers.
Community Manager
June 16, 2020
Hi @dhermosillo, our teams pushed code earlier today to introduce a new "Customer Home" Page to a limited subset of customers. Customers will have seen a 404 momentarily while we rolled out the code, but all should be restored now. We checked just now and the home pages (both the new Customer Home and eSupport Home), and the search feature on each seem to be working fine. Are you still seeing the problem now when you access www.ptc.com/support
Many thanks,
Peter.
