PTC Community Monthly Stand-Out June 2023
achirila
Emeritus
See the Top Community Engagers and the Top Noteworthy posts for the month of June.
Top June 2023 Community Engagers:
@HelesicPetr @Werner_E @MartinHanak @avillanueva @jbailey @tbraxton @LucMeekes @StephenW @buenosroas @Velkumar @kdirth @Chris3 @terryhendicott @jensc @nmutter @VladimirRosu @KenFarley @Marco_Tosin
MOST NOTEWORTHY POSTS
Below are some of the top engaging or most viewed PTC Community topic threads for June 2023!  See if your community username made this list! Or, read more about a topic that interests you!
1. Creo: 1badc20 asked about Work offset does not appear in nc code.
Great contribution byJonathanCook!
https://community.ptc.com/t5/Manufacturing-CAM/Work-offset-does-not-appear-in-nc-code/td-p/881493
2. Creo: Chris12 received an accepted solution from @MartinHanak for topic Post Processor for Tormach 1100MX
https://community.ptc.com/t5/Manufacturing-CAM/Post-Processor-for-Tormach-1100MX/td-p/880300
3. Creo: Thank you YaroslavSin for providing an accepted solution for PM_10505027 on this topic Need an Idea for find the Bodies Parameters in VB Api
https://community.ptc.com/t5/Customization/Need-an-Idea-for-find-the-Bodies-Parameters-in-VB-Api/td-p/883258
4. Creo:  MrSteveR_3 needed help with this topic ProFeatureStatus - feature status not working well with Rep Simp and RPN offered him an accepted solution.
https://community.ptc.com/t5/Customization/ProFeatureStatus-feature-status-not-working-well-with-Rep-Simp/td-p/881941
5. Creo: A question about User Defined Struct Crashing Creo to Fatally Crash
was posted by MH_10366957 and an Accepted Solution was provided by FV
https://community.ptc.com/t5/Customization/User-Defined-Struct-Crashing-Creo-to-Fatally-Crash/td-p/880168
6. ThingWorx: @TonyZhang gave an Accepted Solution to PK_10315615 for the topicwant to set of session variable one parameter string value to null.
https://community.ptc.com/t5/ThingWorx-Developers/want-to-set-of-session-variable-one-parameter-string-value-to/td-p/883767
7. ThingWorx: The topic How can I obtain the session information of a logged-in user?
 posted by hno received an accepted solution provided by TravisPickett.
https://community.ptc.com/t5/ThingWorx-Developers/How-can-I-obtain-the-session-information-of-a-logged-in-user/td-p/883739
8. ThingWorx: jensc provided a speedy response and Accepted Solution to the inquiry by MT_10719574 about GetloggedProperty, selected row, add target causes existing data binding lost.
https://community.ptc.com/t5/ThingWorx-Developers/GetloggedProperty-selected-row-add-target-causes-existing-data/td-p/882105
9. ThingWorx: George_B asked Is there a way to create a new service once you have opened a Service for a Thing (DB or JS) and PEHOWE provided a quick Accepted Solution.
https://community.ptc.com/t5/ThingWorx-Developers/Is-there-a-way-to-create-a-new-service-once-you-have-opened-a/td-p/881767
10. ThingWorx: Arun_C posted the topic Tab Widget - CSS for Tab selected and received an Accepted Solution from Velkumar.
https://community.ptc.com/t5/ThingWorx-Developers/Tab-Widget-CSS-for-Tab-selected/td-p/883765
11. Vuforia: nishihira shared a post about "Is it possible to put HTML elements inside a 2D widget?"
Thank you  for providing an Accepted Solution!
https://community.ptc.com/t5/Vuforia-Studio/Is-it-possible-to-put-HTML-elements-inside-a-2D-widget/td-p/884240
12. Windchill: SC_8321054 posted the topic difference between delete from Windchill and delete form Windchill and directory server and received an Accepted Solution by shussaini
https://community.ptc.com/t5/Windchill/difference-between-delete-from-Windchill-and-delete-form/td-p/883599
13. Windchill: TG_10187670 asked about the Save as from workspace - files location
 and  provided the Accepted Solution. Thank you jbailey,for your contribution as well.
https://community.ptc.com/t5/Windchill/Save-as-from-workspace-files-location/td-p/883442
14. Windhill: jfrancis asked about What is an IBA? with an Acccepted Solution from cgorni
https://community.ptc.com/t5/Windchill/What-is-an-IBA/td-p/124226
15. Windchill: leoffabris asked about Menu Actions > New > New Change Request hidden by validator and  provided an Accepted Solution!
https://community.ptc.com/t5/Windchill/Menu-Actions-gt-New-gt-New-Change-Request-hidden-by-validator/td-p/883825
16. Windchill: Amirtharaj_K asked a question about Modified History and  delivered an Accepted Solution.
https://community.ptc.com/t5/Windchill/Modified-History/td-p/883543
17. Mathcad: DFrancke needed help with Exporting a matrix to Excel with VBA
and    provided the Accepted Solution!
https://community.ptc.com/t5/Mathcad/Exporting-a-matrix-to-Excel-with-VBA/td-p/884279
18. Mathcad: QS_10727930 needed with "Insert a matrix into a larger matrix at certain positions Stiffness matrixand  helped with an Accepted Solution. Thank you terryhendicott for participating as well!
https://community.ptc.com/t5/Mathcad/Insert-a-matrix-into-a-larger-matrix-at-certain-positions/td-p/884340
19. Mathcad: S1 asked about the Define symbolic variable and solve it Mathcad 8
 and  provided the Accepted Solution. Thank you ttokoro,for your contribution as well.
https://community.ptc.com/t5/Mathcad/Define-symbolic-variable-and-solve-it-Mathcad-8/td-p/883875
Andra
0 REPLIES 0
