6-Contributor
October 5, 2022
Deeplink to Vuforia Studio Experience Service with Spaces in Project Name
  • October 5, 2022
  • 3072 views
im trying to create QR codes to deeplink to experiences that have spaces in their project name, such as
'Sample Project'
If I urlencode the whole thing to something like
vuforiaview://ptc.com/command/view-experience?url=https%3A%2F%2Fvf-es.ptc.com%2FExperienceService%2Fcontent%2Fprojects%2FSample%20Project%2F
and build a QR code, the link is shown to be invalid.
Without the spaces, e.g. for a 'SampleProject', everythings fine.
Am I missing something here and is there a way to fix this?
Thank you so much
Best answer by RolandRaytchev
I see that internally to handle this it use "_" underlines ,Possible a question of Studio version
Hi @CS_9203536 ,
so seems that space is working also for qr code example:
https://view.vuforia.com/command/view-experience?url=https%3A%2F%2Fmyexperienceservice.studio.thingworx.io%2FExperienceService%2Fcontent%2Fprojects%2Fspace%2520project%2Findex.html%3FexpId%3D1
  So when you publish the project and then go the share button - it generates the deep link and also the qr code
So I used a project named   "space project" and it was encoded to "space%2520project"    so means that here in QR code is used for space %2520     the url decoder e.g. https://meyerweb.com/eric/tools/dencoder/ will suggest %20 which will not work there
6-Contributor
October 7, 2022
Hi @RolandRaytchev,
thanks for your response. So, it does not even work for QR codes created by Vuforia?
Does that mean there wont be any kind of fix for that?
Thanks and best
