java.lang.string cannot be cast to java.lang.Integer
  • February 7, 2024
  • 2 replies
  • 3591 views
Hello, when loading New Document, it gives the error shown in the picture.
I changed the attribute of the document. I made All Attribute data types string. I keep getting the same error. Would you support?
The template is in excel format. All attributes have been inserted..
Best Regards
Selim AKCELIK
Best answer by egun
Hello Selim,
This might be happening due to post-upgrade issues.
try reload the doc preferences on windchill shell by using the command below:
windchill wt.load.LoadFromFile -d <windchill_path>\Windchill\loadFiles\preference.documents.xml
HelesicPetr
Hi @selim_akcelik
What about your source input xls file?
What type are the columns ?
PetrH
Hello @HelesicPetr
Is this the answer to your question?
HelesicPetr
I'm not sure what is Metin
But I would try to use String
PetrH
egun7-BedrockAnswer
7-Bedrock
March 15, 2024
Hello Selim,
Hİ @egun
Thank you for the successful solution.
