Jamal Ashraf
Nov 5, 2025 1:50 PM UTC
Share data or services between two independent modules within the same main project
Hello everyone,
I have a setup where I’m working with a main project (Project A) that contains all the Things with configurations for two sub-modules:
  • Project A – SubModule 1
  • Project A – SubModule 2
Each sub-module is component of Project A, and all configurations are stored in Project A’s Things.
We have already published Project A as an extension on the production server, so both sub-modules are currently working independently (i.e., there’s no direct dependency or linkage between SubModule 1 and SubModule 2).
Now, we have a new requirement where we need to access data from SubModule 1 inside SubModule 2.
However, due to the independent structure and the way Project A is packaged, I cannot simply make one module depend on the other.
💡 My current idea:
I’m considering creating a ThingTemplate inside the main Project A, and then creating corresponding Things for both SubModules 1 and 2 based on that template.
I could then write shared services inside this template and use the “Allow Override” option if I need to customize the logic separately for each sub-module.
This way, both modules would stay independent, but still have access to a shared service layer through the template defined in Project A.
Is this the best practice for achieving communication between two independent modules under one main project?
OR
Is there any alternative pattern that allows controlled data exchange or service usage between sub-modules while keeping them decoupled?
Any suggestions or best-practice guidance would be highly appreciated.
Thank you! 🙏
Support
Nov 12, 2025 6:53 AM UTC
Hi @MA8731174,
How exactly did you implement the sub-module concept within a single project in ThingWorx?
How did you create a component (sub-module) for a project?
Are Sub-Module 1 and Sub-Module 2 two separate projects, both depend on Project A (Set Project A in the Project Dependencies field in Project > General Information tab)
Providing some screenshots of your setup or modeling in ThingWorx could help community members understand your question better.
Also, please provide more explanation on why you cannot simply make one module depend on the other.
Best,
Jamal Ashraf
Nov 12, 2025 7:38 AM UTC
Thanks for your response!
To clarify — I have Project A as my main core project, and Project B and Project C both depend on Project A. The reason for this setup is that some customers only require Project B and some only need Project C, so I’ve separated them to keep things modular and maintainable.
In Project A, I’ve defined all the core configurations, datasets (Things), and shared logic that both projects can use. Each project (A, B, C) is deployed as an extension, where:
  • Project A has no dependencies.
  • Project B and Project C both depend on Project A.
  • Project B and C each have their own SQL databases.
Now, the new requirement is that some data entries from Project B need to be shared with Project C and vice versa, because certain operations in one affect the other.
However, I want to avoid any direct dependency between B and C — otherwise it will quickly become spaghetti code and hard to maintain.
My idea is to use Project A as a middle layer, probably with a ThingTemplate or common service structure, to allow both modules to exchange data indirectly through Project A. I’m also considering the Service Override option in Things to handle customized logic for each project cleanly.
Would appreciate your thoughts if this approach sounds good, or if there’s a better recommended way to structure this kind of cross-module
communication in ThingWorx.
Support
Nov 12, 2025 8:03 AM UTC
Hi @MA8731174,
Thank you for your clarification. I understand your use case now.
In this case, for example, if Project B needs access to data in Project C but cannot depend on Project C, the only options left are 1) move the required logic to Project B directly or 2) to Project A, which Project B depends on
If you think the logic is reusable by both Project B and C, then the second option - moving the logic to Project A is definitely better. So yes, I think your approach in mind sounds good.
As for whether to use ThingTemplate or ThingShape, you can refer to the following documents.
Example: Using Things, Thing Templates or Thing Shapes
Modeling: Why do I have Thing Shapes and Thing Templates?
Best,
