Jan 30, 2026 4:25 PM UTC
Windchill part type definition - best practices
Version: Windchill 12.1
Use Case: What are the best practices / recommendations in terms part management practices? I'm interested what other organizations do, how many part types you manage and what they are. Our company is manufacturer / provider of industrial automation.
avillanueva
23-Emerald II
Jan 30, 2026 6:04 PM UTC
If you are referring to Soft Typing parts, I have some experience with it.  They are useful if you want to have different part types with different sets of attributes, initialization rules, icons, lifecycles, access right rules, version schemas and workflows. The kicker is that once created of a certain type, there is not "supported" way of changing the type. Not easily that is. So its up to the end user to get it right and right the first time.
When we started using Windchill, we created soft types for parts and docs. We ran into maintenance issues like I illustrated above requiring lots of admin fixing.  Since then we reduced the use of soft types and used PartsLink to handle the various part types. Most of what we wanted was unique attribute sets. Since PartsLink allows for things to be classified at any point, easy to fix errors. Short answer, walk careful into this and if you can avoid the complexity, do so.
HelesicPetr
Feb 2, 2026 1:40 PM UTC
Hi all,
My recommendation is Create an own wtpart  subtype even thou you are not planning to use more sub soft-type WTParts.
Always create own one that is not the root one.
You can easily add the additional subtype in the future and split the usage as you need. ACL OIR etc.
if you do not do that, you will have more work in the future with changing the used root wtpart type to correct one.
PetrH
prerev_kompan
Feb 2, 2026 12:31 PM UTC
I would create a entity-relation diagram as a start.
Which objects do you need?
Which attributes for every object?
Are there any special connections you need to consider?
We have a huge information model with 10+ different types and many attributes.
Some of it might be "nice to have" down the road, but our integration with other applications might also require extra types to be created.
Community Moderator
Mar 18, 2026 10:56 AM UTC
Hi @MK_9853382,
Anurag
Mar 25, 2026 1:47 PM UTC
Probably not a best practise, but throwing it in out of curiosity whether someone points it out as something never to do...  😁
We have three part types used in hierarchical fashion. All have different set of attributes and the cogwheel-icons are of different color  😉
The topmost is a collecting object referencing basically only a project number, ie. not an actual 'part'. It's not going through approvals etc, basically just to make navigation (a lot!) easier for the folks not in engineering. Maybe folders for projects would be preferable instead, but the structure tree is pretty handy.
Second level are products / sales items for the project. Approvals & revision rules apply as the project proceeds and EBOMs evolve. There can be several under a project.
Lowest level are your 'typical' WTPart EBOMs. Engineering has started to use these also as collecting objects for WTDocs...
Works for us in ETO business.
HelesicPetr
Mar 26, 2026 7:17 AM UTC
Hi @HJ1
Why not.
You can use the wtpart types as you wish and your imagination shouldn't stop you 😄
One company wanted a process planning without mpmlink because the price :D.
So I advice them to create own type of wtpart for the process plan and operations.
These types were in the structure of a working parts..
The PP was not part of integration with ERP as a bom but it was moved to erp as a process plan with operations and so on..
Any example of usage is welcome here.
So if you are open for any idea you can try it if it would work.
PetrH
