May 30, 2023 9:26 AM UTC
Windchill performance improvement - most methodical way?
the users are complaining about the "Windchill performance". There can be various reasons and there are various tools/knowledge hubs/cases from PTC to attack the problems hiding behind that general complaint.
I searched for a morning and got the links below. Unfortunately, that list is too big, too chaotic, has duplicates and crosslinks inside
Main question: Is there a recommended, methodical way to analyse and solve Windchill performance problems, by PTC/by you?
Side question: Is there a service by PTC that does it? What were your experiences? (result, cost, specified period, actual period, communication quality, responsiveness)
Thank you.
Windchill-Performance
Lists 50+ cases to increase the performance
https://www.ptc.com/en/support/article/cs303555
General Performance Troubleshooting in Windchill PLM
Lists another ~50 cases to increase the performance. Downside: “Windchill Performance administrator must have strong skills and advanced knowledge of Java and the JVM.”
https://www.ptc.com/en/support/article/cs384986
Windchill System Performance Tuning
Description of specific actions and links to external sources.
https://www.ptc.com/en/support/article/CS153338
[Knowledge Hub] Windchill PLM – Profiler
Tutorial, how to capture a profile plus further links
https://www.ptc.com/en/support/article/cs54838
[Knowledge Hub] Windchill PLM - Search/Advanced Search Performance(beta version)
Links to search specific cases
https://www.ptc.com/en/support/article/CS391852
[Knowledge Hub] Windchill PLM - Application Server Performance
Lists six measurements in, described in other cases
https://www.ptc.com/en/support/article/cs358216
[Knowledge Hub] PTC Performance Advisor
Links to other cases, also to Creo Performance Advisor
https://www.ptc.com/en/support/article/cs358220
[Knowledge Hub] Windchill Workgroup Manager Interaction with PDMLink - Recommended Initial Performance Client Settings
https://www.ptc.com/en/support/article/CS140968
Recommended database indexes for Windchill 11.0 and later releases
Download of script needed, for Oracle and SQL, lists cases
https://www.ptc.com/en/support/article/CS262774
PTC System Monitor Resource Page
Documentation for diagnostic and monitoring solution by PTC
https://support.ptc.com/appserver/wcms/standards/support_resource_page.jsp?&im_dbkey=142899&icg_dbkey=917&source=Bloop
https://www.ptc.com/support/-/media/support/refdocs/PTC_System_Monitor/6,-d-,0/PSMInstallDeployGuide_Windchill_174031.pdf?sc_lang=en
https://www.ptc.com/support/-/media/support/refdocs/PTC_System_Monitor/6,-d-,0/PSMAdminUsageGuide_Windchill_174022.pdf?sc_lang=en
"Find in Structure" performance in Windchill
https://www.ptc.com/en/support/article/cs194963?source=ArticleViewerRelated
[Knowledge Hub] Windchill PLM - Oracle Database Performance
https://www.ptc.com/en/support/article/cs358210
May 30, 2023 1:29 PM UTC
That is a long list of articles.  The links below are not in the list above.
What version of Windchill are you using?  PTC and the third-parties fix performance issues when they can.  For example, the latest DB patches are always recommended and there aren't any articles for tuning Java in the latest releases.
The users' complaint is too broad.  Performance to an end user is how responsive it is in their browser.  Local computer resources, client configuration, and network issues can make a smoothly functioning Windchill appear flaky and slow.  It may not have anything to do with Windchill.  I start by interrogating the end users' complains.  Is it everyone, select people, random?  What functional aspect of Windchill is being impacted? etc.  That helps me determine if it is a server, network, or client issue.
In general, Windchill performance tuning starts at the DB, then moves on to the Windchill-DB configuration, client configuration, and finally investigating potential network issues.
I like to tune the cache values periodically (~every 6 months).  Appropriate cache values change as the DB grows.  The WCA is a place to start and the On-Demand System Scan may highlight other cache values that need adjusting.
I run an On-Demand System Scan and upload the results to PTC.  It returns suggestions in a few minutes.  This ensures there isn't something obvious I'm missing.  FYI: I create a custom System Configuration Collector scan to capture most of the information the On-Demand System Scan wants.
Java tuning is also necessary if Windchill is running on Java 1.8 or earlier.  Getting these values correct can be tricky.
If none of this resolves the issue, I log a Windchill Performance related call with PTC's performance team.  They guide me through deeper troubleshooting and resolutions.
May 30, 2023 1:48 PM UTC
wonderful, thanks a lot, especially for the additional links!
Our local supplier is only acting based on the method-server logs. I wish there  would be a more strategic way, a way that "hits every bush" (as we say in germany) to fix it.
I agree, you need to ask the users to some extend, but at some point it's more efficient to ask the system itself. Most of the users neither have the knowledge nor the motivation to find sources of failures.
We're using 12.0.2.5.
Did you do before/after performance tests? How?
PTC's performance team: Is that more kind of an "one time call" for an hour, where they find one to three issues and fix them, or is that more kind of an "elaborate investigation"?
May 30, 2023 2:40 PM UTC
We typically don't do before/after performance validation.  We are resolving known performance issues with known performance fixes.
Performance baselining becomes relevant when we don't have confirmation from PTC of the limited impact of the resolution.  It can be useful if you are customizing your environment and need to confirm no adverse performance effects before going live.  True performance tuning (setting a target performance, baselining, changing the configuration, and measuring the improvement/degradation) is a tedious and time consuming process.  We try not to go there if we can help it.
PTC Tech Supt has a small group of people who know how to fix Windchill performance problems.  They have tools and experience to read DB performance table exports, Windchill Profiler results, and other requested performance analysis information.
You can start with a call to PTC Tech Supt and they will guide you through the process.  However, I try to resolve as many obvious issues as I can before logging a PTC Tech Supt call.  I feel it shortens the investigation time when Tech Supt isn't finding several obvious performance issues that I could have found on my own.
tarik_perc
May 20, 2026 12:01 AM UTC
Let me share my thoughts about this topic as I have certain background regarding this list…
The list is too big because Perf is cross-cutting, I think having a hub or article per functionality or server was a good approach!! If the architecture of this list is explained, one can take out the most of it!
First, figuring out from which side the perf is coming is not easier, and having to care about all aspects/all servers would be very difficult and complex, for instance, if you don’t have Solr you don’t have to care about indexing performance (enterprise search perf) and hence dropping all recommendations and troubleshooting techniques related to it.
I think you should make it simple, because I do agree perf investigation is not simple!!
If the user is complaining from “Windchill perf” this wouldn’t help much! At least he or someone else should investigate further and see which functionality is impacted, try to rule out options one by one, the more you limit the behavior, more you identify root causes, sometimes certain conditions change result, for instance the time at which the action is done, how many users connected simultaneously, asynchronous tasks running, etc.
The question of managing perf can be thought as follows:
  1. Hardware Sizing: before you install Windchill, you choose best hardware requirements based on PTC recommendations, and your solution (you can only know how many users you would use the app, how many expected input/output operations etc.), there is certain calculation that give you the min sizing.
  2. Initial & Periodical Perf settings: Once the solution is running, you can always tweak it, periodically, following best practices, such as tweak certain properties, java heap memory sizing, postpone certain tasks such as (vis) publishing etc. The hardware is always a limitation, and hence first option is necessary but not sufficient!!
  3. Just-in time investigation: Whenever you notice slowness, investigation starts, the good thing about perf is that is does not stop the solution from functioning 🙃, otherwise, we are not talking about a perf issue but something else. Many tools exist that will help you identify causes and then fix it!
Perf aspects are not only by functionality/server component, but also by customization, both light and hard! for instance bad customization could be the issue or just a custom attribute created from the UI for which a new db index should be created!
In addition to many servers that the web solution is using, Windchill is often used in conjunction with other solution such as ERPs/WWGM, and hence makes perf issues ambiguate! Without to say that Windchill itself is primarily written in Java which is memory-consuming!
I finish by saying that perf is cross-cutting, all servers are tight to each other. The issue could be the database, or network latency, etc. but the behavior could be seen on Windchill not because its the root cause, but because its functionning is relying on all that stack!!
But I do agree that perf articles/hubs still need clean architecture as there are many duplicate links as you said and overlaps….
HelesicPetr
May 20, 2026 7:27 AM UTC
Hello ​@Andy_Admin
First thing I would do is a On-Demand System Scan
Collect the performance and config info from Windchill by the System Configuration Collector
Pack all outputs and send to the On-Denabd System Scan.
It can give you a first help what can help with the perofrmance.
Second
run Windchill Config Assisntant (WCA) with configureCacheManagerSizes option
ant -f utilities/wca/WindchillConfigAssistant.xml configureCacheManagerSizes -Dpropagate=true
then optimize Database indexes and index fragmentation. It can improve performance. Do it regularly once per a half year
Also do not forget to recount SQL statistics after rebuild
There are many discussions  how to optimize all indexes that are fragmented more then 50% etc.
MSSQL Procedure for rebuild indexes with fragmentation more then 30%
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
-- Author: <HELESIC,,PETR>
-- Create date: <2024-09-12,,>
-- Description: <REBUILD PROCEDURE ALL INDEX FRAGMENTED MORE THEN 30% - condition,,>
CREATE PROCEDURE WindchillDB.AV_REBUILD_ALL_INDEXES
AS
BEGIN
-- Declare variables
SET NOCOUNT ON
DECLARE @tablename VARCHAR (128)
DECLARE @execstr VARCHAR (255)
DECLARE @objectid INT
DECLARE @indexid INT
DECLARE @frag DECIMAL
DECLARE @maxfrag DECIMAL
-- Decide on the maximum fragmentation to allow
SELECT @maxfrag = 30.0
-- Declare cursor
DECLARE tables CURSOR FOR
SELECT TABLE_NAME
FROM INFORMATION_SCHEMA.TABLES
WHERE TABLE_TYPE = 'BASE TABLE'
-- Create the table
CREATE TABLE #fraglist (
ObjectName CHAR (255),
ObjectId INT,
IndexName CHAR (255),
IndexId INT,
Lvl INT,
CountPages INT,
CountRows INT,
MinRecSize INT,
MaxRecSize INT,
AvgRecSize INT,
ForRecCount INT,
Extents INT,
ExtentSwitches INT,
AvgFreeBytes INT,
AvgPageDensity INT,
ScanDensity DECIMAL,
BestCount INT,
ActualCount INT,
LogicalFrag DECIMAL,
ExtentFrag DECIMAL)
-- Open the cursor
OPEN tables
-- Loop through all the tables in the database
FETCH NEXT
FROM tables
INTO @tablename
WHILE @@FETCH_STATUS = 0
BEGIN
-- Do the showcontig of all indexes of the table
INSERT INTO #fraglist
EXEC ('DBCC SHOWCONTIG (''WindchillDB.' + @tablename + ''')
WITH FAST, TABLERESULTS, ALL_INDEXES, NO_INFOMSGS')
FETCH NEXT
FROM tables
INTO @tablename
END
-- Close and deallocate the cursor
CLOSE tables
DEALLOCATE tables
-- Declare cursor for list of indexes to be defragged
DECLARE indexes CURSOR FOR
SELECT ObjectName, ObjectId, IndexId, LogicalFrag
FROM #fraglist
WHERE LogicalFrag >= @maxfrag
AND INDEXPROPERTY (ObjectId, IndexName, 'IndexDepth') > 0
-- Open the cursor
OPEN indexes
-- loop through the indexes
FETCH NEXT
FROM indexes
INTO @tablename, @objectid, @indexid, @frag
BEGIN
PRINT 'Executing DBCC INDEXDEFRAG (0, ' + RTRIM(@tablename) + ',
' + RTRIM(@indexid) + ') - fragmentation currently '
+ RTRIM(CONVERT(varchar(15),@frag)) + '%'
SELECT @execstr = 'DBCC INDEXDEFRAG (0, ' + RTRIM(@objectid) + ',
' + RTRIM(@indexid) + ')'
EXEC (@execstr)
FETCH NEXT
FROM indexes
END
CLOSE indexes
DEALLOCATE indexes
-- Delete the temporary table
DROP TABLE #fraglist
END
GO
Some script for the sql orecle definitely exists.
PetrH
