3-Newcomer
Mar 16, 2026 7:43 AM UTC
WVS publishing strategy – generate viewables only in In Work and keep them for later lifecycle state
Version: Windchill 13.0
Use Case: Hello, We are running **PTC Windchill 13 with **SolidWorks 2024 integration. Visualization files are generated through WVS using a SolidWorks worker. We are trying to optimize publishing load and would like to change the publishing strategy slightly. Our lifecycle is approximately: Concept → Prototype In Work → Prototype Released → In Work → Under Review → Released → Obsolete Goal During normal design work (In Work), every CAD check-in generates the visualization viewable (Creo View / PVZ). When the design leaves the In Work phase, the geometry should no longer change. Therefore the last check-in in In Work would effectively be the final viewable generation. After that point: the existing viewable representation should remain attached to the CAD document / WTPart it should simply carry forward to the next lifecycle states Later, when the object is promoted to Released, we only want to generate the final deliverables: PDF (drawing) DXF (if parameter DXF_CONVERSION = YES) STEP (if parameter STEP_CONVERSION = YES) In other words: In Work check-in → generate viewables Promotion to Released → generate only PDF / DXF / STEP Do not regenerate viewables during promotion Manual Republish should still remain available if needed. In that case the system could regenerate: viewables PDF DXF / STEP (if enabled)
Description:
Is this publishing behavior achievable using standard Windchill configuration (for example WVS Publish Rules or workflow publishing settings)?
More specifically:
  • Can viewable generation be limited to the In Work phase, while later lifecycle transitions only trigger the required deliverable formats?
Any best-practice recommendation or configuration example would be greatly appreciated so we can discuss this with our Windchill service provider.
Thank you.
Some of the replies to this topic were published during the recent read-only period. We have manually republished the missing posts to preserve the integrity of the topic. Learn more.
April 2,2026
The Community team
Catalina
Community Manager
Mar 20, 2026 8:06 AM UTC
Hi @DESIGNER_JT
Thank you for your post.
Best regards,
Catalina | PTC Community Manager
3-Newcomer
Mar 20, 2026 10:54 AM UTC
Thanks for the follow-up.
Let me simplify the question and add a concrete example.
Target behavior (simplified):
  • In Work (check-in) → generate viewables only
  • Released (promotion) → generate PDF / DXF / STEP only
  • No automatic regeneration of viewables after In Work
  • Manual republish should still regenerate everything if needed
We are considering whether this could be controlled using WVS Publish Rules.
For example:
This is a conceptual example of what we are trying to achieve.:
<rules>
 <authoring-application name="SOLIDWORKS">
 <!-- In Work → create viewables -->
 <condition>
 <attribute name="epmdoc_lifeCycleState" value="INWORK"/>
 </condition>
 <publish on="checkin"/>
 <publish on="create-representation"/>
 <!-- Released → only deliverables -->
 <condition>
 <attribute name="epmdoc_lifeCycleState" value="RELEASED"/>
 </condition>
 <publish on="unknown-source" output="PDF"/>
 <publish on="unknown-source" output="STEP"/>
 <publish on="unknown-source" output="DXF"/>
 </authoring-application>
</rules>
Why we want this:
Currently the worker spends roughly 1–2 minutes per file generating viewables.
When a Promotion Request is executed to Released:
  • viewables already exist (from In Work check-in)
  • but they are still regenerated again
This creates unnecessary load on the worker and results in:
  • long publish queues (2–6 hours)
  • delay in getting PDF / DXF outputs needed for production
We are specifically trying to avoid unnecessary worker load during promotion.
Question:
Would this kind of setup work in practice so that:
  • viewables are only generated during In Work
  • Released publish does NOT regenerate viewables, only additional formats
We are using a hosted environment and cannot test this ourselves, so any guidance or correction would be highly appreciated.
Thank you!
18-Opal
Mar 21, 2026 6:34 AM UTC
Hi @DESIGNER_JT,
This should be feasible, please refer to the following articles for guidance.
However, I do not believe it is possible to generate only additional formats without regenerating the viewable. Additional formats are typically generated as part of the publishing process.
https://www.ptc.com/en/support/article/CS365574?source=search
https://www.ptc.com/en/support/article/CS152784?source=CS365574
https://www.ptc.com/en/support/article/CS81396?source=CS365574
https://www.ptc.com/en/support/article/CS111916?source=CS365574
