Add pdf,giff or image to Pro/E drawing
  • June 29, 2011
  • 744 views
Need to help to place graph in proe drawing. Graph is converted to pdf. Used option to bring or even create object or file were not very successful image is fuzzy or just creates look like icon. Any idea?
Thanks in advance
3-Newcomer
June 30, 2011
Create New is the way to insert the PDF. Create from File basically inserts a shortcut to the file. However, we have had issues where inserting thePDF is low resolution and can not be read. So we insert a JPEG or Bitmap to get better resolution. You will need to convert the PDF to a JPEG or Bitmap and then Insert - Create Object - Bitmap Image. At the top left of the screen choose the Edit menu and Paste From. Navigate to the image file you created and open it. You should be able to open any picture file. The insert may fail if the file size/resolution is too much for Pro to handle. I keep reducing the image file size or resolutionuntil Pro takes it.After the image works,click anywhere in the drawing andthe image will be fit to the box.The boxmay need to be resized to get the correct proportions.
