Assembly family tables in WF5
  • May 2, 2011
  • 0 replies
  • 513 views
We recently made the jump from WF3 to WF5 and I am having issues getting some of my assembly family tables to work. To test it out, I created a simple pin (with a diameter and length) and put it by itself in an assembly. I created an assembly-levelfamily table so that I can show the pin at nominal, maximum, and minimum values on my drawing. So, I created a parameter called "State" and then I have an instance in my FTfor each state. I have relations in my assembly that look something like this (where d0 is the length of the pin):
IF STATE == "NOM"
