2-Explorer
September 26, 2014
component installation quandry
  • September 26, 2014
  • 761 views
I need to figure out how we are going to install a particular component in an assembly where things are tight. What's the best method for determining and showing this? So far, I'm assembling the component in various positions, and will show each position separately. I'm afraid I'll miss potential interferences along the way. Are there better ways of doing this?
Thanks in advance for any help you can give me.
Kind regards,
Janet Grove
If you assemble the component using Mechanism constraints you will be able to perform a Mechanism Analysis 'Playback' that will stop the component if it encounters a collision or interference situation. This requires the user to have the configuration file option enable_advance_collision set to a value of yes as well as the Collision Detection Settings dialog box options 'Global Collision Detection' and 'Stop When Colliding' selected before executing the Mechanism Analysis 'Playback'.
