creo 3.0 Reverse arrows dimensions
In creo 2.0 and all previous versions, during the dimensioning operations, it was possible to reverse the position of the arrows, with a click on the right mouse button.
In creo 3.0 this is not possible, you have to confirm the location the dimension, and re-select the dimension and right click, reverse the position of the arrows.
This is because during the dimensioning, the click of the right mouse button brings up a menu of options dim.
The solution is to use a quick click of the right mouse button to swap the dimensions, and a slow click to bring up the menu.
