Flexible parts issue question.
  • January 20, 2010
  • 4152 views
Is there a way to make the parameter PTC_MATERIAL_NAME flexible at assembly? I'm trying to get a part to change material and appearance at the assembly level in certain cases, and in this case I can't make an instance of the part itself and change the material (via the PTC_MATERIAL_NAME) in the instances. The parameter seems to be invisible both when I try and make it flexible at the part and at the assembly level. I can make the MP_DENSITY change, but it would be much cleaner if I can change the material itself as that way I'd get the material properties (not just density) and apperance as well. Thanks!
I do this all the time via execute and input statements. Here is an example where "MATERIAL" is my driven parameter, and I use "MAT" for reporting in the description: IF MATERIAL==1 PTC_MATERIAL_NAME="S30100" MAT="Type 301 SS" ENDIF IF MATERIAL==2 PTC_MATERIAL_NAME="S30400" MAT="Type 304 SS" ENDIF IF MATERIAL==3 PTC_MATERIAL_NAME="NYLON" MAT="Black Nylon" ENDIF
You can change the material by adding the PTC_MATERIAL_NAME to the Model Tree Columns by typing it in from the Model Params type. In the part select the materials you want to be in the model. You can assign an appearance to the material so that when you change from one to another the color changes. In the assembly you should get a drop down list that lists the materials in the part model that you can change between.
DELETEME1-VisitorAuthor
