GD&T help
- June 6, 2012
- 8 replies
- 6241 views
Can anyone explain to me what is meant by this marking? This model came
from a vendor. Is the B datum just the centerline of the circle?
Also, this same hole has a drafted side and mates with another part with
an o-ring between them. What would be the best way to dimension this so
that the part works as intended. The original 23mm dimension is
technically gone since there was a draft added and a round added at the
top & bottom.
top & bottom.
