hi
  • August 29, 2013
  • 0 replies
  • 712 views
iam working in air conditioners manufacturing company in saudi arabia,
i need to create a assembly that controlled by family table and final assembly.
please help me how can i create..
example : i want to create a sitting table it contains legs of same section but different lengths and the section is same but some feature are additional in some legs.
what i did is i create a leg and created additional features and then create a family table and generate instances with different lengths with some yes/ no additional features for instances.
than i assemble these legs in final assmbly (that sitting table), now what i want to do is the lengths of legs to be totally dependent on final assembly not family
table. how can i do.
what i did is i create assembly parameters (example x, y, z) write relations length of horizontal leg = x, length of vertical leg = y , length of top leg = z ... like this
when what i face a problem is when i change parameter values (x,y,z) the lengths of legs cannot be changed....
please help how can i do.
thanks
shaik
