how can i change line width of cutting line and detail circle only?
  • September 5, 2012
  • 2 replies
  • 8169 views
how can i change line width of cutting line and detail view circle only?
    do anybody know this? is it possible in wf5 ?
    I took a look at this and it seems questionable. The "section line" is a Geometry line weight and the circle is appearantly leader line weight. This is pretty much locked in as I cannot seem to select the circle as a "curve" nor access section line geometry. I haven't seen anything that assigns line colors specifically to section elements. If this was the case, then you could play with the pen tables.
    My tests are done with standard ASME settings. I don't know if other standards would yield different results. I suspect you are simply expected to follow a known convention in this regard. Kind of silly not to open this up to user preference.
    One thing I did note is that you can "Break" the section line if that helps clarify a view.
    i hv also tried many ways but didnt get desierd result. thanks u for trying thing to help me out.
    i think creo should improve its detailing platform a littel bit more . user should hv the option to change any individual line. By just selecting them user can change its width & type. In addition to this creo should also hv the capabilty to chnge the the line width of outlines of TABLE, this is one more thing which should be consider.
    if any one knows anything plz share
    - thanks & regards
    Dalbeer Singh
    File -> Prepare -> Drawing Properties -> Detail Options (change)
    Search for "detail_circle_line_style"
