6-Contributor
June 24, 2015
How to scale a model in Creo
  • June 24, 2015
  • 2 replies
  • 2296 views
I was trying to find out if it is possible to scale a model in Creo to a 1:1 ratio? If so, how would I go about doing that?
Look at your list character by character across.
D01-XXX-1 comes before D01-XXX-3.
Typical computer sort problem that has always existed and always will.
Instance name is text string and therefore names are sorted alphabetically.
Martin Hanak
If you want it to sort properly the names need to be:
D01-XXX-092
D01-XXX-030
D01-XXX-050
D01-XXX-105
D01-XXX-076
ps-46-ContributorAuthor
6-Contributor
June 25, 2015
Thank you Ben, I will request to my customer for changing part numbers as your suggestion
Mahesh_Sharma
22-Sapphire I
July 1, 2015
Prabhu,
Mark the appropriate reply as correct answer. Or you can add you comments to post and mark that as correct answer.
