HP Printer Problem With Wildfire 3
- March 23, 2012
- 0 replies
- 429 views
Hi Guys:
I have recently converted some of our workstations to Windows 7 64bit. We went this route as we can run some of the company programs in XP mode as they won't install to 64 bit OS hence I can't use XP 64bit. We are still using Wildfire 3 m220 (64bit) as we are in the middle of a long Windchill upgrade from 8 to 9.1.
Now my problem is with printing. Our HP Laserjet 5200 prints fine with XP and our HP 1055 designjet prints fine in XP and Windows 7 (once I found the right driver that would recongnize the multiroll feeder.......). I have installed the 64bit print driver and I thought it was printing fine. Then I started getting complaints about text that was yellow and object lines that where green. When printing these colors it is not picking up on the green or yellow pen widths. They are printing far too light and in some case in shades of gray. I logged a call with PTC and they don't support my printer any more or Wildfire 3 in Windows 7 so they gave me the SOL line and the call ended there. Any kind of help would be appreciated. I included our .pcf and .pnt files for the printer in a zip file if you wish to look at them.
Note: I believe I have fixed the gray problem by setting the printer settings to print all text black and Send Graphics as Vector.
