Interference check for solid geometry only?
  • January 31, 2012
  • 9 replies
  • 12314 views
Does anyone know how to do an interference check that discards surface geometry? My checks always have lots of irrelevant information in them about construction surfaces. It would also be great if I could check interference between specific parts within an assembly rather than the whole assembly at once.
Anyone got any ideas? I'm on Wildfire 5.
Best answer by mrbrandau
Hi David,
With regards to your second question... I also want an easy way to select a few parts to check interference, limiting the analysis to just those parts. The only way I can figure out how to do it is to create a simplified rep of just the parts to be analyzed and then run global interference check. This should limit the analysis to only what's visible.
view manager > simp rep tab > properties button > hide the entire assembly > select the parts you want to run the analysis on > run global interference check
I can't figure out any other way to do it (which is why I searched and stumbled onto this thread). Hope this helps.
If you run a "Global Interference" you shouldn't have this problem. There is a box you can check to include quilts. I just added a surface part to an assembly & it did not come up when I ran the clearance check. I am also running Wildfire 5.0.
David_M1-VisitorAuthor
Hi Mike
This seems to have worked in terms of eliminating the quilts, but it’s still including parts which I don’t want it to, and therefore giving a much longer list than is needed (and taking a lot longer). Is there any way to choose parts? If not I could settle for a way of exporting the list so I can filter it in Excel.
Global Interference check is great for finding the little interferences you forget about. I have never had any problem with it. It doesn't lie. I don't know how your model is setup but you can run the check on sub assemblies also. I am not aware of a way to filter your results within PROE. My goal is to always have no interferences. Good luck!
mrbrandau1-VisitorAnswer
Hi David,
One quick option is to use the ANALYSIS > MODEL > PAIRS CLEARANCE option, and then filter by PART or COMPONENT. This will allow you to select either parts or sub-assemblies and check for either clearance or interference. If there is clearance, the minimum value will be displayed. If there is interference, the volume will be displayed. Hope this helps.
It's even quicker to pick the parts first and then click pairs clearance.
There is now way out to carry out selective clearance and inteference checks on assembly. you can visit www.dfmpro.com or visit PlanetPTC 2012 booth # 611
