Mechanism sub assembly assembled multiple times in a top level assembly?
  • March 24, 2011
  • 2 replies
  • 777 views
Good Day All,
Has anyone found a way to assemble multiple mechanised sub assemblies in an upper level assembly without making the sub assembly a family table allowing each of the mechanism sub assemblies to maintain different states in the upper level assembly?
Maybe a enhancement request by all is needed?
Don A
Dan McCaherty confirmed that it could be done.
My problem appears to be that the parts on the right side of the system are not exactly on the same centerline.
I removed the insert constraint and just used a mate constraint by it's self and the system works.
So just make everything is on the same centerlines and no rounding error differences and all with work just fine.
Dan, Thanks for the help.
Don
Oh, and make sure no regen values are asigned to the mechanism in the sub assembly.
