7-Bedrock
January 21, 2010
naming standard hardware
  • January 21, 2010
  • 2502 views
We are building a library of standard hardware to use, AN3 bolts and NAS washers etc. There is plenty of discussion on naming convention though. For example, an AN3-5 Bolt, should the model (in a family table) name be exactly the physical part name (an3-5.prt), or should we suffix the part name ".xyz" (an3-5.xyz.prt) to avoid possible conflict with any other hardware (legacy, or from other customers) who may have also built a AN3-5 Bolt. I don't want to make the name any more difficult that it needs to be, but I see benefits to the extension. How do other companies handle this? Thanks, Bruce
What I've done at the last 2 companies I've created hardware libraries for, is the generic has a prefix of: "L-G_", and the instances have the prefix "L-I_", and then I had a system where the filename described the fastener type, size and length. Now, that gets kid of lengthy, and I had to do that for my current company because they didn't have a part numbering system for fasteners. the first company created a P/N for every part (including fasteners), so it was very easy to make filenames in that case. The prefix's allow for easy searching and displaying in both a IntraLink and/or PDMLink environment (Workspace/Commonspace etc.), or a Windows environment.
avillanueva
23-Emerald I
January 22, 2010
We had purchased a mil spec library from a company called ParaCAD many years ago. I do not think they are still around but we choose to use the exact milspec part number as the filename. So nas1352c.prt would be the generic and nas1352c04-6.prt would be an instance.
BPapp7-BedrockAuthor
7-Bedrock
January 22, 2010
Antonio, that is one reason we want to "personalize" our library, so in a file sharing situation we do not have duplicate names. The downside to this is, if I want an AN3-5A I need to type in our added filename also(eg AN3-5A_ATS). Thank you both, one argument per side... I will wait and hope a few more users weigh in. Bruce
