Notes question
  • March 3, 2010
  • 3725 views
Does anyone know how to insert a surface finish symbol into a note on a 2D drawing? (This symbol is not in the text symbol box.)
WF4.0 M91 Click Insert > Surface Finish > Retrieve. • Double-click the Machined folder. • Select the standard1.sym symbol. etc.
i think he meant in the note like when creating a parametric note using & at the beggining Carlos Diaz
March 3, 2010
Nick We usually leave a large space in the note and place a standard surface finish symbol in the blank location. It is not directly inserted into note. Now you could make a symbol that had the note and the surface finish if you are going to use it more than once. Regards Eric
