Printing; label colour when printed?
  • November 3, 2015
  • 2 replies
  • 3269 views
This is more an annoyance really, with what I hope is some incredibly simple answer that I have missed.
When I print my drawings I always include a label as a time stamp for the print. Now my question is why is the label sometimes green and sometimes black?
What determines the colour of the label?
Many thanks,
Miles
This is a pnt file
See Specifying Location of Pen Table File
And Example table pnt File
Or printer option of course
But that's the thing, my pen table file does not change yet the colour of the printed label does?
It is not in the printers options either as if you preview the print in Creo you can see the label colour.
I initially thought it was green on the first print and black if reprinted. However that does not work.
FYI Creo 3.0 M060 but I did also notice this behavior in Creo 2.0.
I use Creo 2
  • This reproduce on other computer?
  • Can you share your pcf file ?
Miles,
please upload example data.
Use How to attach file when you Reply to a discussion. method.
MH
Please find attached a drawing that I know has printed with two different colour labels.
On last print the label was green.
I am perplexed as to why Creo does this, but also not that bothered. 🙂
Miles,
I tested drawings.pcf in CR3 M060 and now I can publish results ...
1.] plot_label_height problem
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS220137 reports problem with label height in CR3 M060 (SPR opened)
following setting works (for me)
plot_label_height 0.019685039 CM
!*** 0.1 CM >>> 25.4 mm in printed drawing
!*** 0.019685039 CM (0.1/25.4*5) >>> 5 mm in printed drawing
2.] plot_translate problem
plot_translate 0.000000 -6.000000 MM
3.] pen_table_file problem
pen_table_file table.pnt
The above mentioned setting is "unstable". Always use absolute path to pen table file. For example:
pen_table_file C:\PTC\print_settings\table.pnt
Modify pen_table_file option to fullfil this requirement.
MH
