ProPDFExport - PRO_PDFOPT_VIEW_TO_EXPORT
Hey all,
I want to export a drawing to PDF using ProPDFExport.
As options I use following code snippet since I want to export a special view:
ProPDFOptions pdfOpt;
status = ProPDFoptionsAlloc(&pdfOpt);
status = ProPDFoptionsIntpropertySet(pdfOpt, PRO_PDFOPT_VIEW_TO_EXPORT,PRO_PDF_VIEW_SELECT_BY_NAME);
status = ProPDFoptionsStringpropertySet(pdfOpt,PRO_PDFOPT_SELECTED_VIEW, (wchar_t*)viewNameP);
status = ProPDFExport(drawing, pro_wszPath, pdfOpt);
status = ProPDFoptionsFree(pdfOpt);
at "ProPDFoptionsStringpropertySet(pdfOpt,PRO_PDFOPT_SELECTED_VIEW, (wchar_t*)viewNameP);" I got ProError "Bad Inputs".
So I checked my viewName by using ProViewRetrieve:
ProDrawingDimensionViewGet((ProDrawing)drawing,&dims[i],&viewTemp);
ProDrawingViewNameGet((ProDrawing)drawing,viewTemp, viewName);
ProLine vName;
wcscpy_s(vName, viewName);
status = ProViewRetrieve(drawing, vName, &viewTemp);
To explain: traverse through the dimensions of my ProMdl and ProDrawingViewNameGet works (I get the correct viewName as result). But copying the viewName to vName (ProLine) and then trying to use ProViewRetrieve I get the Error "A general error occurred and the function failed."
Someone any Ideas?
Best regards
Luis
