PTC Creo Elements/Direct Finite Element Analysis Survey
  • March 12, 2015
  • 2 replies
  • 2070 views
Would anyone please let me know if PTC Creo Elements/Direct Finite Element Analysis has the following capabilities for thermal analyses? Any suggestions/recommendations are welcome too. Thanks.
Steady state and transient analysis
Conduction, convection and radiation
Temperature and pressure dependent thermal conductitivity
Anisotropic thermal conductivity
Material propety aliases (for easy re-assignent materials to models)
Automatic calculations of capacitances and linear conductances and radiation conductances thru MLI
Ablation calculations
Calculate interface conductances along surface edges
Thermoelectric coolers
User defined variables for parametric study
Verify model with checking tools (active surfaces, duplicate nodes, overlapping surfaces, free edges etc.)
Organize models using submodels
Manage models with Model Browser
Run multiple analysis cases in sequence
Postprocessing tools for animation, temperature history plots, and temperature contour plots, etc.
Defeaturing tool (remove unnecessary features from CAD models) to simplify model meshes
Built-in functions for modeling primitive shapes, Boonlean Operations, 2D sketching tools
Mahesh_Sharma
22-Sapphire I
March 13, 2015
Quoc,
This is about Creo Elements/Direct hence moving the post to correct category.
qnguyen1-VisitorAuthor
Thanks, Mahesh, for your suggestion. Since I was not able to locate the Creo Elements/Direct category you had mentioned, I decided to post this question again in Creo/Analysis and Simulation/. I hope this will be fine.
I've never used the FEA module for thermal analysis, so I don't know all of the answers:
Steady state and transient analysis - Don't know
Conduction, convection and radiation - Conduction and convection, but I don't believe it handles radiation
Temperature and pressure dependent thermal conductitivity -Don't know, but I believe that conductivity is assumed constant
Anisotropic thermal conductivity -Don't know, but I believe that conductivity is assumed constant
Material propety aliases (for easy re-assignent materials to models) -You can pick materials from a table, so it is easy to assign/reassign
Automatic calculations of capacitances and linear conductances and radiation conductances thru MLI - Don't know
Ablation calculations -Don't know
Calculate interface conductances along surface edges -Don't know
Thermoelectric coolers -Don't know
User defined variables for parametric study -I don't believe that the FEA module can access any parameters and adjust them
Verify model with checking tools (active surfaces, duplicate nodes, overlapping surfaces, free edges etc.) -There are some checking tools, but I don't know if it meets what you are looking for. Most of what you specified should be handled automatically since you would be dealing with solid models and automeshing
Organize models using submodels -Yes
Manage models with Model Browser -I think that the that answer is yes
Run multiple analysis cases in sequence -I don't know of a way to automate the sequence, they would need to be started manually
Postprocessing tools for animation, temperature history plots, and temperature contour plots, etc. -There are postprocessing tools, but since I've never run thermal analyses, I don't know what postprocessing tools are available.
Defeaturing tool (remove unnecessary features from CAD models) to simplify model meshes -Since Creo Elements/DIrect Modeling is an explicity modeling tool, there are plenty of tools to defeature your models.
Built-in functions for modeling primitive shapes, Boonlean Operations, 2D sketching tools -Since Creo Elements/DIrect Modeling is an explicity modeling tool, there are plenty of tools to create primitive shapes.
Thanks a lot, Peter, for your inputs regarding the CAD features. I really appreciate the effort.
