Quick Export Location
In Creo, under "Save As" is an option "Quick Export". I would like to change the default location where files are saved when using the quick export feature. I have searched through all the config options and I can't find a config to define the destination. Does anyone know how to control this? By the way, preferred_export_format config option will allow you to change the format in which the quick export saves in.
